No creo que tengas mucho problema, es un motor con mucho par motor y además con una tara alta. En wahttowcar da para ese conjunto cinco estrellas en verde, por lo que por peso y potencia bien.
Towing Report
Volkswagen and Burstner
The
towing capability for the Volkswagen Touran - 2.0 TDI
with a Burstner Averso 480 TK:
Performance on levelled roads
Top speed
Usability 6th gear
Acceleration and take overPerformance in mountainous regions
Drive off uphill
Driving on motorway slopes
Driving on steep roads
Volkswagen Touran - 2.0 TDI (103 kW/138 bhp)
Date of manufacture: may 2004 - up to now
78%
1300 kg 1658 kg
The match between car and caravan is perfect in accordance with a mix of European standards. However, according to the British Towing Code the percentage (loaded caravan / kerbweight tow car) is
78%.
The towing performances of this Volkswagen with your Burstner are perfect (performance index = 104 km/h or 65 mph).
You may expect excellent performances from this outfit. On flat roads it's easy to come along, in which case top gear is applicable in most cases.
On motorway inclines you will be able not only to come along, but be the first at the top. On steep roads you have more than sufficient power to keep going. On hill starts there will be more than enough power to get going, provided the wheels have traction.
65
20%
