There are different kinds of flooring, which can satisfy different demand for people all over the world. Commonly, flooring is made from wood and other materials, it can be divided into solid wood flooring, laminate flooring, bamboo flooring, cork flooring, geothermal heating flooring, plastic flooring, etc. And different flooring types can be used in different areas, generally speaking, wood flooring and laminate flooring own more wide range in the world. The blow will give you detail information about comparing the best laminate flooring and best wood flooring, and you can conveniently choose the most suitable flooring for yourself.
Laminate Flooring Guide
As we all known that laminate flooring is consisted of four layers, including wear resistance layer, decorative layer, core layer, stabilizing layer. Different layers have some special features, and we can give you the detail laminate flooring guide, the first layer is wear resistance layer which is made of highly-durable cellulose paper saturated with melamine plastic resins to resist abrasion, the layer can be used to protect the laminate flooring from stains, fading and wear. The second layer is decorative layer, which is specially designed with different color and images or photograph. It is the blow of wear layer, we can see it clearly via the wear layer, therefore, it can be protected from being marked, scuffed or fade. The core layer is the main part of laminate flooring, which is composed of high density fiberboard and comprises the bulk of laminate flooring. The layer is also able to be made of high-density wood particles that are hard and difficult to penetrate. The last layer is stabilizing layer, which is made from cellulose paper, just like the first layer, this layer can resistance to water and hold up well.
Wood Flooring Guide
Wood flooring is made of natural wood which is dried and processed form of surface. And it is can show the natural wood texture and color pattern. Wood flooring owns the feature of natural, soft, rich texture, so it can be used widely in different room, like living room, bedroom, etc.
Certainly, whatever laminate flooring or wood flooring, you can get different style products according to different manufacturers. Therefore, when you start to choose flooring, you first know some famous flooring manufacturer’s information. If you choose best laminate flooring manufacturers, I can recommend you “Gentoo floor” or “Sunspeed floors”, if you want to Know total laminate flooring information, you can try “Gentoo floor”.
Generally speaking, comparing laminate flooring to wood flooring, the features of laminate flooring is wear resistance, rich in sytle, impact resistance, resistance to deformation, resistance to pollution, free-retardant, moisture, environmental protection, non-fading, easy to install, easy care, etc. For wood flooring, it owns feature of sound and thermal insulation, humidity control, gorgeous noble, durable. So you can be according to yourself demand to choose the related floors. If you consider the prices of flooring, the laminate flooring prices are much cheaper than wood floors, and you are going to get economical and practical flooring, I strongly recommend you to use laminate flooring.
Wood Flooring Guide
