anmorsa
Siempre tenemos la duda, ¿ Tengo el coche adecuado ?, ¿ Tengo la caravana adecuada ?. En esta direccion podeis ver si realmente estan bien optimizados.
En mi caso la caravana tiene un peso equivalente al 60% del peso del coche, esto es realmente importante.
Consultar esta pagina, para aclarar esa gran duda:
What TowCar.com - All about Towcars and Towing Caravans
Towing Report
The towing capability of the Honda CR-V II - 2.2i-CTDi (103 kW of 140 hp, date of manufacture: november 2004 - january 2007) towing a Knaus Azur 400:
Weight ratio:
= 60% - Speedindex:
= 103 km/h - Max steep incline:
= 22%Performance on levelled roads
Top speed
Usability 6th gear
Acceleration and take overPerformance in mountainous regions
Drive off uphill
Driving on motorway slopes
Driving on steep roads
Outfit match
Conclusion is that The match between car and caravan is perfect. Towing performance on levelled roads
You may expect excellent performances from this outfit. On flat roads it's easy to come along, in which case top gear is applicable in most cases.
Possible top speeds
Possible top speed in windless conditions and head wind force 3Top speed in 3rd gear is 118 km/h and in head wind it will be 117 km/h.Top speed in 4th gear is 132 km/h and in head wind it will be 124 km/h.Top speed in 5th gear is 130 km/h and in head wind it will be 116 km/h.Top speed in 6th gear is 125 km/h and in headwind it will be 111 km/h.
Weight ratio:
Outfit match
60%
1200 kg
1992 kg
Important for safe towing is the weight ratio between Car and Caravan. The ratio for the Honda and Knaus is 60%. (According to the British Towing Code -loaded caravan/kerbweight towcar- this percentage is 71%.) 1200 kg
