Necesito opinión de un conjunto
esferas.
[TABLE="class: tc07"]
[TR]
[TD="class: cc16, width: 299"]Distribución[/TD]
[TD="class: cc30, width: 301"] Dos árboles de levas en la culata, 16 válvulas[/TD]
[TD="class: cc25"] [/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Número de cilindros[/TD]
[TD="class: cc30, width: 301"] 4 cilindros[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Cilindrada[/TD]
[TD="class: cc30, width: 301"] 1.997 cc[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Potencia máxima[/TD]
[TD="class: cc30, width: 301"] 140 Cv / 4.000 r.p.m.[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Par motor máximo[/TD]
[TD="class: cc30, width: 301"] 340 Nm / 2.000 r.p.m.[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Diámetro x Carrera[/TD]
[TD="class: cc30, width: 301"] 85,0 mm x 88,0 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Alimentación[/TD]
[TD="class: cc30, width: 301"] Turbo de geometría variable. Inyección directa alta presión. Cambiador aire/aire[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Relación de compresión[/TD]
[TD="class: cc30, width: 301"] 17,6 :1[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Caja de cambios[/TD]
[TD="class: cc30, width: 301"] Manual de 6 velocidades[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Desarrollo (km/h a 1000 rpm)[/TD]
[TD="class: cc30, width: 301"] 8,4 / 16,1 / 25,6 / 36,1 / 44,3 / 53,7[/TD]
[/TR]
[TR]
[TD="class: cc31, colspan: 2"] --- CICLO ---[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Suspensión delantera[/TD]
[TD="class: cc30, width: 301"] Serie Hidractiva III+[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Suspensión trasera[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Tipo de dirección[/TD]
[TD="class: cc30, width: 301"] Asistida variable[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Diámetro de giro[/TD]
[TD="class: cc30, width: 301"] 11,7 m[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Frenos delanteros[/TD]
[TD="class: cc30, width: 301"] Discos ventilados (304 mm)[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Frenos traseros[/TD]
[TD="class: cc30, width: 301"] Discos (290 mm)[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 299"] Neumáticos[/TD]
[TD="class: cc30, width: 301"] 225 / 55 R17[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Largo[/TD]
[TD="class: cc30, width: 301"] 4.779 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Ancho[/TD]
[TD="class: cc30, width: 301"] 1.860 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Alto[/TD]
[TD="class: cc30, width: 301"] 1.458 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Distancia entre ejes[/TD]
[TD="class: cc30, width: 301"] 2.815 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Vía delantera[/TD]
[TD="class: cc30, width: 301"] 1.586 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Vía trasera[/TD]
[TD="class: cc30, width: 301"] 1.557 mm[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Peso en vacío[/TD]
[TD="class: cc30, width: 301"] 1.683 kg[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Carga útil[/TD]
[TD="class: cc30, width: 301"] 472 kg[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Peso rodando autorizado[/TD]
[TD="class: cc30, width: 301"] 3.755 kg[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Peso remolcable[/TD]
[TD="class: cc30, width: 301"] sin freno 750 kg / con freno 1.820 kg[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Capacidad maletero[/TD]
[TD="class: cc30, width: 301"] 439 litros[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Asientos abatidos[/TD]
[TD="class: cc30, width: 301"] 547 litros[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Depósito combustible[/TD]
[TD="class: cc30, width: 301"] 71 litros[/TD]
[/TR]
[TR]
[TD="class: cc31, colspan: 2"] --- PRESTACIONES ---[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Velocidad máxima[/TD]
[TD="class: cc30, width: 301"] 204 km / h[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Aceleración 0-100 km/h[/TD]
[TD="class: cc30, width: 301"] 10,6 segundos[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Aceleración de 0 a 400 m[/TD]
[TD="class: cc30, width: 301"] 17,4 segundos[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Aceleración de 0 a 1000 m[/TD]
[TD="class: cc30, width: 301"] 32,3 segundos[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Consumo urbano[/TD]
[TD="class: cc30, width: 301"] 7,5 litros / 100 km[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Consumo interurbano[/TD]
[TD="class: cc30, width: 301"] 4,8 litros / 100 km[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Consumo medio[/TD]
[TD="class: cc30, width: 301"] 5,8 litros / 100 km[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Emisiones de CO2[/TD]
[TD="class: cc30, width: 301"] 153 g / km[/TD]
[/TR]
[TR]
[TD="class: cc16, width: 237"] Combustible[/TD]
[TD="class: cc30, width: 301"] Diésel[/TD]
[/TR]
[/TABLE]
tienes muy buen par en ese motor...tirar de ella lo haras sin problemas...
otra cosa es el peso del coche,que si,que son casi 1700kg en vacio,que esta muy bien...
y en la mayoria de los casos iras genial....siempre que no excedas la velocidad...ten cuidado cuando te adelanten los camiones o viceversa
y sobretodo los dias de mucho aire.
yo lo pase muy mal una vez con un coche similar al tuyo y tiro de una carreta de similar peso...y cuando cambie a un tt.....ufff,que bueno.
vamos que en resumen ,,creo que vas a ir bien,,,sabiendo lo que llevas detras,,,y cargando bien el conjunto(pesos repartidos,y cargando mas el coche)
saludos desde Elche.
