pgarcia
Muy buenas...
abrimos la temporada... queremos irnos al camping Los Escullos (Cabo de Gata) en Almería, desde Córdoba. Parece que la bronquitis-otitis de la nena y la laringitis del nene remitirán para el Jueves Santo, que es cuando queremos salir. Mi conjunto renault laguna-caravelair 416 va un poquito justito, ¿me recomendáis evitar el puerto de La Mora? ¿me voy por Iznalloz que no hay tanta cuesta pero es carretera de un solo carril en final de temporada aceitunera?
TowCar me dice que...
The towing capability of the Renault Laguna II - 1.9 dCi (79 kW of 107 hp, date of manufacture: january 2001 - march 2005) towing a Caravelair Antares Luxe 416:
Weight ratio:
= 55% - Speedindex:
= 93 km/h - </B>Max steep incline:
= 17%Performance on levelled roads
Top speed
Usability 6th gear
Acceleration and take overPerformance in mountainous regions
Drive off uphill
Driving on motorway slopes
Driving on steep roads
Outfit match
Conclusion is that The match between car and caravan is perfect.
Muchísimas gracias...
![groen35.gif](http://www.whattowcar.com/images/ster/groen35.gif)
Weight ratio:
![bord_con_weegschaal_klein.gif](http://www.whattowcar.com/images/bord_con_weegschaal_klein.gif)
![bord_leeg_heel_klein.gif](http://www.whattowcar.com/images/bord_leeg_heel_klein.gif)
![bord_steilehelling_heel_klein.gif](http://www.whattowcar.com/images/bord_steilehelling_heel_klein.gif)
![3sterren.gif](http://www.caravantrekker.nl/images/ster/3sterren.gif)
![1sterren.gif](http://www.caravantrekker.nl/images/ster/1sterren.gif)
![4sterren.gif](http://www.caravantrekker.nl/images/ster/4sterren.gif)
![5sterren.gif](http://www.caravantrekker.nl/images/ster/5sterren.gif)
Outfit match
55%
1000 kg
1735 kg
Important for safe towing is the weight ratio between Car and Caravan. The ratio for the Renault and Caravelair is 55%. (According to the British Towing Code -loaded caravan/kerbweight towcar- this percentage is 67%.) ![bord_weegschaal_heel_kl.gif](http://www.whattowcar.com/images/borden/bord_weegschaal_heel_kl.gif)
1000 kg
![pijl.gif](http://www.whattowcar.com/images/borden/pijl.gif)
